Thread: Intex 16x48 pool refill.
    Jul 2010
    Jacksonville, NC
    35
    As, of now I only have some test strips and the Kmart 3 way Aqua Chem drop tester kit.
    I am looking to probably order the tf100 on Wednesday...bear with me! lol
    As of yesterday evening, the 20th, I filled and per the calculator put in
    62 oz. of bleach
    27 oz of Shock Plus.
    Testing chlorine at least 3 times today its very very yellow. It looks to be almost in the 5 ppm though...
    Ph is just a tad high color wise, guessing 7.9ish?
    Using the strips, the stabilizer pad is close to the 50 (ok). I know is not very accurate but...
    Now, this evening what do i do?
    -Joe
    24' X 54" Sharkline Matrix. J-Hook liner.
    2 speed pump, 16" Intex sand filter.
    Apr 2011
    Lynchburg VA
    393
    Re: Intex 16x48 pool refill.
    I would take a sample of the pool water to a pool store and get it tested there. Test strips are more like guess strips IMO, pretty worthless. If you have just filled the pool and have not added any CYA to your pool you can start with the pool calculator and figure out what you need to add in the way of CYA and get that done.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Jul 2010
    Jacksonville, NC
    35
    Thought Shock Plus was CYA?
    --Dichlor - chemical name is dichloro-s-triazinetrione, also called "pool shock".
    It says 58.2% sodium dichloro-s-triazinetrion on label.
    38,371
    dichlor is not just CYA it also adds FC and lowers the pH.
    There is "pure" cyanuric acid CYA that does not add the FC. Dichlor works as long as you track how much you add do the CYA and FC do not get too high.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Jul 2010
    Jacksonville, NC
    35
    Ah, I see.
    That might be wanted to add to the "pool school" for the less inclined... Like this guy
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
