Results 1 to 8 of 8
Thread: Tiny Bubbles - NOT the Don Ho song :)
    I have bubbles in the basket of my pump. Not big ones, the kind that you have to be within 3 ft of the basket to even see. I've replaced the lid o-ring, and tried the garden hose trick, but to no avail they are still there.
    There is a main drain and skimmer line, both 1.5 in. They are controlled by a Hayward sp735 valve, which is hard to find much info on besides parts list http://www.poolpartsonline.com/p-263...ool-parts.aspx. The previous owner told me she hadn't moved the valve in 10 years, It's on 50% Drain and 50% Skimmer.
    The valve and pump are approx 15yrs old. We bought the house last year at the end of the swimming season and I don't remember weather the bubbles where there or not. The pump is quiet when running, no gravelly sound, although the Hayward s244t filter makes some racket, nothing loud, but it's there.
    There is no visible air from the return lines in the pool, however you can kind of tell that the water is aerated when you have goggles on. (and contact lenses in) Not sure if this is from the mostly constant pool party my kids seem to have or from a suction leak.
    1. Is this even a problem? I haven't noticed a leak, water loss seems to be on par with evaporation (bucket test)
    2. If it IS a problem, would the valve be a good place to start (I've already replaced the o-ring, and can't get the winter drain off)
    3. If the valve should be replaced should I switch to the Jandy valve? It seems like that is the standard valve (which may be because the Hayward sp735 was junk?)
    Thanks!
    p
    16x30 20,600 gal Inground Vinyl Pool Installed in 1984.
    Bought house in 2011. BBB. Taylor K-2006 test kit.
    Sta-Rite 1HP pump (looks old). Hayward s244t filter.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Tiny Bubbles - NOT the Don Ho song :)
    Check the water level in the skimmer first.
    Also check the drain plugs on the pump.
    Both of those are easy to check.
    30,432
    If you can see bubbles in the strainer basket lid, it IS a suction leak. They frequently don't present a water leak.
    If it's not bothering you, you can leave it. There is a little less efficiency with the pump and, usually, they make extra noise but yours doesn't seem to be very large. If it's not worth chasing (they are hard to find) then it is not worth chasing.
    Quote Originally Posted by Richard320
    Water level is normal, NO vortex
    Drain plug is frozen, it's an older pump
    Kind of what I figured, does filtering efficiency go down too?
    Any experience with the Hayward Valve? It seams like it way more points of possible leaks than the Jandy one.
    30,432
    only to the extent that you aren't pushing quite as much water through....in your case, that sounds virtually negligible.
    Qwaxalot's Avatar
    Jun 2012
    439
    After running the pump for a while (a couple of hours), while watching the pump lid and drain plug closely, turn the pump off. You're looking for a little spurt of water (caused by the "spring" effect of air in the filter). If you see a tiny spurt, that's the source of your air leak.
    You said the drain plug is frozen. Does this mean you can't get it out, or someone has epoxied it in? I'd look more closely at that.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Quote Originally Posted by Qwaxalot
    Looks like someone stripped the head off of the plug a long time ago, and it's rusted too. I don't dare try to remove it really.
    I was getting the water through the oring on the lid, which is why I replaced it.
