Thread: Air bubbles in the pump
    Hi!
    this morning I attempted to vacuum my above ground pool and mistakenly I let some air to get inside of the system. I can see few bubbles in the motor and small streams of bubbles coming out from the return every 2 seconds more or lees. What should I do?
    Walfred.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Air bubbles in the pump
    Open the air bleed on the filter, if you have one.
    Thanks Richard for your quick response!
    Sorry I couldn't answer you right away, I was invaded by a bunch of friends!!. Well... apparently my filter doesn't have any air bleed and I looked around twice, the good thing is that the bubbles disappeared in 30 minutes leaving only one "stable" bubble in the motor, when I mean stable is because it looks like a device level. The filter sopped doing that squishing sound and no bubbles are coming out from the return. In this case is ok to leave it as is or should I keep looking the way to get rid of the big bubble inside of the motor?
    Walfred,
