Thread: Adjust TA?
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Adjust TA?
    My most recent readings. I am adding 238oz of bleach to get to 6ppm. Would you adjust anything else? My TA seems to be going up. My Simple Pool app says to reduce my pH to 7.5 with acid and then aerate to increase pH. Pool calculator says it should be 70-90+
    FC 1
    CC 0
    pH 7.6
    TA 120
    CYA Not Tested
    CH 130
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Re: Adjust TA?
    In an above ground pool without a SWG or fountain and reasonable CH levels, TA at 120 is just fine. Don't worry about the TA being a little high unless you find the PH going up rapidly or CH increases dramatically.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Re: Adjust TA?
    Cool, thanks Jason. My CH has been stable from day 1 and pH is going down rather than up. I will not worry about it.
