Thread: Polaris 3900 sport, Seems sluggish out of the box..
    May 2012
    Summerville, SC
    39
    Ok so my Polaris 380 case cracked and I mentioned it to my mom, who very generously sent me the 3900. I hooked it up and made all the adjustments it said to in the instructions (except cutting the cord yet). The sweeper hose with the new guard that doesn't let it fly wildly out of the water is very very slow (the tail barely wags on the highest setting). (My filter pressure was at 10 about the lowest it gets after backwashing) Out of the box it was at 30 rpm so we took off the restrictor and it's at 32 rpm. It just appears very slow, and I'm just not sure if it's this sluggish new wear may make it useless. I was happy with the old 380 (which I am going to repair for winter use anyway). So I guess I'd just like to hear from anyone with experience with this machine. We had a storm last night and it's been on for about an hour with a good chunk of the leaves picked up. I am going to check it right at 2 Hours and see how it looks. All told though, its better than vacuuming manually.
    18x36 in ground (24,000 gal) vinyl liner
    Hayward super pump 1.4hp, Pentair IC40 salt generator
    Hayward sand filter, Polaris 380 (3/4hp Hayward booster pump), Pentair Intellibrite Color
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Polaris 3900 sport, Seems sluggish out of the box..
    If your polaris moves to fast it will out run what it is trying to pick up. The tail sweep hose should move in a gental sweeping motion. So what seems slugish to you may be ok.
    May 2012
    Summerville, SC
    39
    Indeed, I believe you are right. Less than 2 hours later the pool is spotless. My 380 never accomplished that in that amount of time, more like 3 - 4 hours if I was lucky.
