Results 1 to 8 of 8
Thread: Should i lower PH? .... newbie question but why did it rise?
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Quick backrground ... first year on BBB and have had clear water since day 1 and have added nothing but chlorine after a batch of stabilizer in the beginning. My numbers have been perfect all along.
    I even went on a week of vacation and managed to educate my 18 year old daughter enough to have her maintain it while i was gone for 8 days .... my only concession was to leave the solar cover off so i didn't have to alter my daily dose based on whether it was in use ... and returned to a clear pool!
    My ph has always been right around 7.5 .... and it now reads over 7.8 but below 8.2 so i am guessing 8.0 or so
    current results from this morning
    FC 5.0
    CC 0
    TC 5.0
    TA 110
    CH 200
    CYA 40
    so my questions are should i lower ph?? ... if so shoot for 7.2 or 7.5 ... pool calculator shows 31 oz of MA to get to 7.5
    is it worth doing anything else
    any thoughts as to why it would rise? .... we had a bunch of rain recently and pool went up 2 or 3 inches
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Should i lower PH? .... newbie question but why did it r
    It went up because the rainwater aerated it, most likely. What was TA before you left?
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by Richard320
    i'll post shortly ...... my notebook with all my past readings is in my car that the previously mentioned 18 year old has now
    i am almost thinking my ph may have been creeping up slowly as i think about it
    thanks as always
    Haywood Sand Filter
    Vinyl Liner
    Nov 2011
    Albany, NY
    495
    Ok
    just checked my logs ... yikes... that sounds like i know what i am doing
    my TA when i opened the pool in mid may was reading 110 - 120 .... by late june it was 90's and stayed that way through 7/6 when i did my last comprehensive testing
    my ph was low (high 6's) when i opened and i bumped it up and it was reading 7.8 by 5/23 and held there through 5/30 then dropped down to 7.4 by 6/27 and held there through 7/6
    i did spot test more often between the dates noted and remember them to be between 7.5 and 7.6 or 7.7 but i only record the comprehensive test results in my log unless i get an abnormal reading (hasn't happened until today )
    i just bought plain muriatic acid at lowes ... they had plain and safe so i assume plain was correct
    as i mentioned pool calculator shows 31 oz or so to go from 8 down to 7.5
    should i do more and go to 7.2?
    should i do anything with my TA?
    is adding the MA simple?? and how long do i need to wait after adding it?
    if it requires down time for the pool are we ok swimming at 8.0 for the day and then doing my magic tonight??
    and lastly do my changes sound normal / about what i should be expecting?
    Haywood Sand Filter
    Vinyl Liner
    Richard320's Avatar
    Jan 2010
    18,988
    The plain acid is great. It probably says 31.45%/ 20 baume. And that's what you want. 7.5 is a good target. TA will settle itself as long as you keep pH in range. Adding acid is easy. Measure it out and dribble it in in front of a return. A couple swipes with a brush to disperse it and let the kids in, they'll finish mixing it.
    38,275
    Generally you want to let chemical additions mix for at least 30 minutes, might be safe before then though.
    The less you handle the acid the better. I prefer to lower the bottle into the water so it kind of floats and slowly pour it over a return. This does not allow prefect measurements, but you can estimate pretty closely based on how much of the bottle is dumped in. Just retest a little while after the addition to see if you hit the target.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Nov 2011
    Albany, NY
    495
    Quick follow up in case anyone finds this while searching and wanted to know the outcome along with a couple questions.
    Put in 1/4 or so of a gallon of MA - calculator called for 31 oz to get it down to 7.5 so i figured i could estimate a little ...... checked it this AM and it was 7.4
    If i am understanding things correctly i can expect a slow creep up again over the next month like i saw over the past month?
    My TA of 110 is a bit on the high side but i should be ok... or should i lower it a bit??
    If i can expect a slow creep am i better off adding a little bit of acid on a weekly basis if i see it creeping up?
    Haywood Sand Filter
    Vinyl Liner
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Everything is fine where it is, TA can be between 80-120, so your in target with it, Chlorine in all forms (except gas) is Alkali so will slowly raise your pH, the TA just stops the violent swings in pH in your pool chemistry. Just keep doing what your doing and add a little Acid when needed.
    Stuart
    Stuart Murray
    Scotland UK
    UK NPPOC
