Thread: Aquapure 1400 error 170/193, then no power
    I just replaced the cell, after getting a 120, 121 error code, and the voltage reading at the cell was high (38). New cell has been working great for about a week. This morning I went to turn the cell down, as chlorine levels were a little high. The cell was not showing on the PDA. Went to the control box, and the lcd was blank on the front panel and it showed no power. cut the breaker off, and back on and it gave a 170/193 error. Cut the power to disconnect the sensor to test the front board , and now the front panel does not come on. The incomming voltages are reading correct. Any ideas?
    16x34 Freeform Inground Vinyl Pool / 244T Hayward Sand Filter / Gold Line Aquarite Salt System
    Polaris 380 / Cabo Tile w/ Blue Pebble Bottom Liner / Cantilever Coping / 4x8 Fiberglass Steps - For The Dog!
    Build Completed July 2012
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Aquapure 1400 error 170/193, then no power
    No idea, sorry! Welcome to TFP! Hopefully someone will come along who can answer your questions.
