Results 1 to 9 of 9
Thread: Pool calculator
    Pool calculator
    How do I make the water in my pool match up to the pool calculator? Meaning I should have a 10500 gal pool. but when I add the bleach it never goes to were I was trying to get it. Let's say I want to go from 4fc to 7 fc. I end up more like 11 every time. Right now I play bleach dice. See what calculator says than go under. If is says to add 96 oz I may add 50oz. Sometime I'm right sometimes I'm wrong. It is getting costly to keep testing the water. I will prob have to order more reagents again soon. This will be my third time ordering if I can't get this under control.
    AG 15x30 4 ft deep 12000 gal.
    Aqua Star 100lbs Sand Filter model fs019
    Installed june 2012
    30,411
    Re: Pool calculator
    Correcly identify the size of your pool first. You sig says 15' x 30' by 4' deep. Is that absolutely correct? Is the water 4 feet deep? Do you have rounded corners?
    Re: Pool calculator
    Yes the pool is round on the egde. The wall are 54 inches. so best guess it 4 ft.
    15x30 oval abg pool 54 in walls.
    Installed june 2012
    30,411
    Re: Pool calculator
    How long are the straight sides before it begins to curve? Got a pic? Does the manufacturer state the gallonage?
    Re: Pool calculator
    What's your CYA? Do you have the correct bleach %?
    18K Gals, Intelliflo VSD, Pentair Catridge, SWG, Solar & Gas Heat, Pebble Tec, Jandy AquaLinks, Pool Pal for Android.
    Re: Pool calculator
    I can post a pic of pool later today. my cya is 40. I use, 6% bleach. Clorox, Family Dollar, etc, what ever is cheaper. Pool calculator is always set for 6%.
    Installed june 2012
    22,543
    Re: Pool calculator
    Some dollar store bleaches aren't 6%. That may be part of the problem.
    Re: Pool calculator
    The bottles I have say 6%. Could they be higher than the bottle says?
    Installed june 2012
    Re: Pool calculator
    It is rare for them to be higher, lower is fairly common. I've heard of 6% being 8%, but never higher than that and not at all common.
