Thread: Jandy PDA to iAqualink
    Mar 2011
    Houston, TX
    72
    I currently have a Jandy PDA system but the PDA stopped working after it was left in the rain. I am going to put it in a bowl of rice to see if it dries out. In the meantime I was reading about the iAqualink system and can't figure out how to convert my current system. Any ideas?
    18,500 gallons, Cartridge Filter, In Ground Plaster. Jandy CL460 Filter
    Aug 2010
    Austin, TX
    200
    Re: Jandy PDA to iAqualink
    Figure out which unit you have. Out the box, the iAqualink comes in two versions for up to 8-relay models (PDA8, RS8). One for older control systems, and one for newer systems. If you have a larger system than an 8-relay unit, you will have to send your current CPU board to Jandy to upgrade (silly IMO, seems like they are worried people will upgrade their systems to higher-end models...).
    Basically, all you need is an iAqualink to program/control your aqualink. You don't need a PDA or a control interface anymore, though you can use all three together at the same time. The iAqualink acts as its own, and can be used over the web in a browser or a smartphone app. Its user interface modeled after the touch control interface.
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
    Mar 2011
    Houston, TX
    72
    How do I determine which unit I currently have? Can't get the PDA to power up.
    Aug 2010
    Austin, TX
    200
    I wish I could help you on that one. I'd assume you have a PDA8 system if installed in the last 2 years. Call Jandy customer support.
