Thread: Pool Levels
    Pool Levels
    Hey guys. First post but been lurking around in the background for a while learning what I can. I have an Intex 15 ft x 42 inch deep metal frame pool that I plumbed in 1 1/2" PVC and hooked to a 19" TWM sand filter with a Hayward Powerflo LX, 1 1/2 hp I think. Anyway here are my levels according to my Taylor K-2006. Let me know if I'm missing something but I think it's close to where I need to be.
    FC - 3.0
    CC - 0.5
    PH - 7.4
    Alk - 120
    CH - 160
    CYA - 50
    Thanks
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Pool Levels
    Welcome to TFP
    With 50 CYA the FC should be between 4 and 8 and never below 4.
    Other than that, your #'s look just fine.
    You're done SLAMing when:
    Re: Pool Levels
    Thanks. I guess I over did the Cynaric Acid a little. I would like to keep the chlorine level down around 3 if possible. Don't want the bosses hair to turn orange.
    38,371
    Re: Pool Levels
    Welcome!!!
    Keeping the FC level at 7ppm with CYA of 90ppm is the equivalent active chlorine level as a FC level of 2ppm with CYA of 25ppm
    And both are WAY less active chlorine than you would find in a public pool with a FC of 1ppm and 0ppm of CYA.
    You are perfectly safe to swim in your pool up the the shock FC level ... for 50ppm CYA that is a FC of 20ppm.
    No worries ... just enjoy!!!
    But, if you do want to turn people hair colors ... put a LOT of copper in your water and you will see green hair .... JK do not really do that.
    Re: Pool Levels
    This is great news. Now my mind is at ease. I can up the chlorine without worrying about the side effects. I've been adding about 3 oz of algecide each week also and water is extremely clear other than the normal bugs each day. This has been a good test to find out how much trouble it would be to keep a pool up. Actually hope I can get the Garden Leisure Nova pool next year. I think it's actually made by Wilbar. Time will tell though as getting the ground prepped and level for this pool was a royal pain this the Red Clay I live on plus the hillside I live on. Ground drops about 8 inches over a 15 foot span.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pool Levels
    Welcome to tfp, epoxyoyo
    Quote Originally Posted by epoxyoyo
    Using an algaecide is typically not needed if you maintain the proper level of chlorine (for your cya level). If you do use a algaecide, use a 60% polyquat...and never use an algaecide with copper in it.
