How do I "dial back" pump pressure?
Jul 20, 2012
4
I got a deal on a new Hayward Perflex EC75A de filter. According to Hayward this filter should be matched to a pump with a 30-100 GPM output. However, my 2 hp pump delivers 110 GPM. What are some options to "dial back" the pump pressure to less than 100 GPM? Would installing a check valve between the pump and filter help?
Thanks in advance for any suggestions.
Welcome to TFP!
You really shouldn't use that filter with that pump. There are some ways to work around the flow rate issue, but they are rather more complicated than matching the pump to the filter correctly and they also waste electricity besides. Do you really need a 2 HP pump? The simplest thing might be to install a smaller impeller in the pump, which will reduce it's effective HP.
I have an oddly-shaped pool with a spa. Best guess is 15-20k gallons.
Based on everyone's comments the Hayward EC75A would be too small for my set-up (Sta-Rite Dura-Glas II up-rated 2 hp pump with 2" piping throughout). Oh well, back on Craig's List it goes.
How about a 31" sand filter, such as the Hayward Pro Series with a 4.91 ft filtration area? I'm replacing a 14-year old Pac-Fab FNS-48 de filter that's given good service but is on its last legs.
Oh I missed that you posted this. Even that filter is too small for that pump IMO, it also has a peak flow rate of 98 gpm (JL may have been referring to this filter in his last post and not the EC75A).
By the way, the EC75A has a max residential flow rate of 100 gpm (though it would be better at a max "public" design rate of 80 gpm).
Looking at the pump curves and 50 ft of head, that pump will put out about 117 gpm.
