Thread: Eye irritation and pH level
    Oct 2011
    Minnesota
    164
    Hello all,
    All things being equal for other parameters: what level of pH will cause less eye irritation?
    Low pH of around 7.2 or high around 7.8?
    Thanks
    20x44 IG vinyl. Intelliflo, Pentair Cartridge Filter (420ft^2), Raypac 336K, Kreepy Krauly
    Re: Eye irritation and pH level
    Low PH has much more of an effect on your eyes than high PH. Most people feel some eye irritation below 7.2, though a few people start to notice problems at 7.2 or even just slightly higher (quite rare however). On the high end you can go up quite a bit over 7.8 before you notice anything.
    Mar 2007
    San Rafael, CA USA
    12,082
    See this post for more details about studies on eye irritation and pH. Chloramines were much more irritating than a pH what was off unless it was WAY off (outside 7 to 9). The salt level also had a lot to do with preventing irritation (human tears have around 9000 ppm salt). Nevertheless, we occasionally get some reports as Jason noted where it seems that being too low in pH is more noticeable than too high (relative to 7.5).
