Results 1 to 14 of 14
Thread: Ugghhhhh
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Ugghhhhh
    Just got a new liner and refilled pool, got balanced and the pump just stopped working! Checked the outlets they are fine, pump was working just fine and stopped. Feels hot, should I just wait to see if it cools down. I have no Idea what happened.
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Re: Ugghhhhh
    It might have lost prime. That is fairly common if the water level is a little too low and the skimmer forms a vortex that draws in air. Of course there are lots of more serious problems that could be going on instead, but lets hope it is one of the simple ones.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: Ugghhhhh
    I'm not sure, I'll go see if I can get the lid off to get the prime back. It was dead silent, but now is making a humming sound when I turn it on.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: Ugghhhhh
    Nope, full tank or whatever it's called. Went ahead and loosened it, to prime just in case. Still just a faint humming.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: Ugghhhhh
    I think the motor is seized, really hot to the touch and a light humming noise. It's about 6 years old with no other problems guess I shouldn't complain, but I just got everything else right and now this...grrrr!!! If I decide to buy a new pump, maybe a 2 speed, anyone have any suggestions?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: Ugghhhhh
    Quote Originally Posted by pepsiholic
    I thought about upgrading when my pump did what you just described. But it was fastest to just disconnect the wiring and undo six bolts and replace the existing motor with an exact replacement. I let the pool store guys mess around swapping the plate and impeller when they sold me the motor. I think I was down maybe 4 hours.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: Ugghhhhh
    Richard, funny thing. I unplugged the pump and let it cool down, just plugged it in and turned it on again and it started right up. I think I have an airleak somewhere, though. I see a little cyclone thingy by the return, but I don't know where to look for the air leak.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Ugghhhhh
    If you are getting a vortex in the skimmer, try putting in your basket and see if that helps.
    -- Guy --
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: Ugghhhhh
    The vortex isn't in the skimmer, it forms right above the return and when it hits the return water coming out it makes a very loud annoying noise. Any suggestions on what might be causing that? I'm going to take the lid off the pump and check to O-ring again, I cleaned and greased it this spring but maybe it needs it again. I'll also check the plug on the pump, was planning on doing all this last night but got rained out.
    Re: Ugghhhhh
    If your return is the common eyeball type, you can loosen the collar a bit, by turning it counter clockwise, and then reposition the return, to avoid that vortex. A vortex like you describe, is usually just caused by the return's orientation, and not by a leak.
    Tom
    In gound vinyl L, ~41,000 gallons, Pentair Clean and Clear Plus 420 cartridge filtter, Pentair 2 speed WhisperFlo pump
    30,431
    Re: Ugghhhhh
    It is the flow of the return water into your pool and causes absolutely no harm. If it is annoying to you, deflect the return water downward or more upward and it will probably stop.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: Ugghhhhh
    Oh, ok, I can do that ..haha.. I still have a little air in the pump. I see a little water around the clamp thingy and it is pretty rusty, so I'm going to go to walmart and pick up a few of those.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: Ugghhhhh
    Good news guys. Found the airleak, just needed some new teflon tape between the shutoff valve and the basket...lol...boy do I feel silly, but thanks for all your help!
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Ugghhhhh
    It was probably easier to hear without that irritating return vortex.
    -- Guy --
