Thread: Safety Cover UV Protectent?
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    Spoke to the pool cover company -- they said their standard cleaning process is to combine dawn dish soap + hot water in a 5 gallon bucket, clean the cover with that, dry....and then apply an UV protectent to the top surface of the cover (however, the person I spoke to didn't know the brand or specs).
    Has anyone heard of what UV protectent is used for safety covers and if it truly prolongs the life of the cover w/o adding non-desired chemicals to the pool?
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
    South Central NJ
    3,192
    Re: Safety Cover UV Protectent?
    All decent safety covers resist UV for 10 years at a minimum, most for 12 or so, This is out of the box. Hosing the cover off after any debris is removed and a possible brushing off with a nylon pool brush is all that is needed. The use of detergents and UV protectants is not needed or wanted since they get in the pool water.
    Scott
    Owner of - PoolGuyNJ LLC
