Thread: CLR
    CLR
    can you clean a cart in CLR?
    8500 Gallon AG/WaterWays HiFlo pump/ClearWaterII Cartridge Filter 100 sqft (replaced in July 2012)/ TF-100 test kit/BBB & Muriatic Acid system
    Southwestern Pennsylvania
    Oct 2011
    Minnesota
    164
    Re: CLR
    Not sure, but the normal recommendation is to use TSP for cleaning the cartridges. If you do a search, you will find the correct mixture for TSP use.
    20x44 IG vinyl. Intelliflo, Pentair Cartridge Filter (420ft^2), Raypac 336K, Kreepy Krauly
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: CLR
    As long as you rinse thoroughly, you can probably get away with it. From a cost perspective, it is likely less expensive to use one of the cartridge soaking solutions.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
