Results 1 to 15 of 15
Thread: Pics of where I'm at with my pool
    Jul 2012
    Toulon, Illinois
    43
    After all the help I have received from this forum, here are some pictures of where I am with my pool currently. Thank you all for the help and I'm sure I will be asking many more questions.[attachment=0:37cl0wv0]072012103629.jpg[/attachment:37cl0wv0]
    21 foot by 4 foot AGP, Jacuzzi Laser 192 sand filter, Hayward 1 HP pump, approx. 9100 gallons, install 7/15-7/17/2012
    Jul 2012
    Toulon, Illinois
    43
    Re: Pics of where I'm at with my pool
    [attachment=0:2o2panxl]072012103531 (480x640).jpg[/attachment:2o2panxl]
    Apr 2012
    SW Ohio
    456
    Who poured chocolate milk in your pool?
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Apr 2012
    SW Ohio
    456
    You got some work ahead of you.....I have seen worse....It's do able
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Do you have a test kit and current test numbers?
    Are you shocking?
    How long has it been this way and is it improving?
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    get LOTS of bleach.
    Jul 2012
    Toulon, Illinois
    43
    I'm waiting for test kit to arrive. I just have a cheapy one from walmart right now. Chlorine is at .5 and PH is 7.8. The local fire dept brought out water for us, we are 8 miles from nearest town. The water had a lot of iron in it. I will be shoking it tomorrow. Trying to see how well the pump and filter will do(monitoring very closely). It is improving from yesterday...seems to just be a slow process. I'm hoping to have it swimable by Sunday or Monday as our temps are going to be up into the high 90's again.
    Articfox918's Avatar
    May 2012
    Western, Wisconsin
    99
    We had the same situation when we first installed our pool water truck brought water high in Iron....I would suggest a sequestriant also
    POOL SIZE: 27 FT round 52" Deep on edges 66" Deep in center
    FILTER TYPE: Hayward Sand Filter
    PUMP SIZE: Hayward 1 HP Pump 60GPM
    FILTER SIZE/FLOW RATE: Unknown
    HEATER: None at the moment but in process of making my solar panels should be operational by next season!
    Jul 2012
    Toulon, Illinois
    43
    Put sequestriant last night...sorry must have thought it but didnt type it.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Work with ChemGeek or one of the metal-knowledgable posters here. pH has a lot to do with metals. Using the incorrect sequestrant can add other chemicals you do not want in your pool there are only a few recommended brands here. See Pool School for more info.
    I have seen several postings where they tie a cotton sock to the return and place paper towels in the skimmer basket to help trap the rusty debris. If you do this, be sure to watch your flow, your pressures and make sure your pump doesn't lose flow. It may need the water flow to keep it cool and running safely.
    -- Guy --
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    I'm sorry, but your pool will not be swim-able by Sunday or Monday. It's best to not even think it's possible.
    Have you read Pool School a few times? I think it'd be good if you focused on the green swamp information. Brown water and metals aside, you're going to need to do the shocking process for a number of days.
    Following the information here will allow for the fastest turnover possible. Promise.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    If your CL levels are good... that's great
    The most important thing when you water is cloudy (other than CL) is to make sure the pump and filter are working 24/7 until the water is clear. No chemical will remove cloudy debris and rusty or red dirt, only the filter. Let you pressures rise to 25% over your clean pressure. If 10 PSI is clean, let it rise to 12 or13 before doing a backwash. In a sand filter, it is helpful to let your filter get "a little dirty" to improve performance. DE can be added but it will require more attention but may make the process faster if you dedicate your time to it. See Pool School for more about this.
    -- Guy --
    Jul 2012
    Toulon, Illinois
    43
    Thanks everyone. I've read pool school like 20 times and still find myself confused. I'm more of a hands on kinda person. Reading doesnt do much for me.
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by SadieBailey
    Ask questions and we'll try to help - maybe with pics.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Once you get the test kit in action then you'll start to see some action/reaction and start to understand how the various chemicals impact the water.
    I'm the same way, reading is critical but hands on helps me understand much better.
