Thread: Cal-Hypo in an Colored Plaster pool on a DE filter
    efm1972's Avatar
    Jul 2012
    Philadelphia, PA
    19
    My pool is recently installed (plaster completed on May 3, 2012). I have been using Tri-Chlor pucks all season and have seen a recent uptick in CYA due to the heatwave here in the northeast. My CYA average so far this season has been 40 - 50, but last two readings are 90, hence my desire to change to a unstabilized chlorine alternative. My current readings are as follows:
    FC - 3.0
    CC - 0
    pH - 7.6
    TA - 100
    CH - 250
    CYA - 90
    I have a few questions regarding the use of Cal-Hypo in a colored plaster pool that is running a DE filter.
    (1) Can Cal-Hypo stain an Onyx Ansylbrite (colored) plaster pool irrespective of CH level?
    (2) If Cal-Hypo is thoroghly mixed in a 5 gallon bucket of water before adding to pool (and sediment at bottom of bucket is not dumped in), is there any potential for staining or any other problems/issues with using Cal-Hypo in an Onyx Ansylbrite (colored) plaster pool if the CH is 250?
    (3) Can using Cal-Hypo long-term cause any damage to a DE filter?
    Thanks
    18,500 gallons, DE filter, IG
    Jandy Pump 1.0 HP, Zodiac Filter (flow rate = 120 gpm)
    Installed May 2012
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Re: Cal-Hypo in an Colored Plaster pool on a DE filter
    You're still going to be adding Calcium, which can eventually lead to scaling on your pool.
    Why not just use bleach? No unwanted additives, no premixing.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Your CH is at the low end of the ideal range. Adding CalHypo is going to drive that number up at a fairly fast pace. Using bleach would eliminate this risk.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    efm1972's Avatar
    Jul 2012
    Philadelphia, PA
    19
    Thanks for the suggestions on the bleach. I will most likely switch to bleach.
    Installed May 2012
    30,424
    If your CYA tests 90 again in a second test, I would drain/refill to get it back to 40-50ppm and use bleach for the rest of the season.
    Don't use Cal-hypo.....your overdose of CYA will diminish it's effectiveness causing you to likely overdose on Cal-hypo to compensate. Cloudy water and scaling can result.
