Thread: Pool Care After Major Rainstorm
    Last night I found myself out in the the middle of a huge rainstorm (in MD) with the filter on backwash trying
    to get the water level down so it doesn't go over the pool. My question is: After a major rainstorm where so
    much water is added to the pool and then having to drain water out the pool, is the best course of action
    to check the CYA level to see where it is at and adjust if necessary? Test chlorine and ph and adjust...should
    I worry about bringing the pool to a higher chlorine level than normal just in case? CC all summer long has
    been .25 or 0. FC has never gotten lower than 4 and CYA is around 30.
    The pool has been amazingly easy with the BBB method and the TF test kit, just don't want a huge rainstorm
    to mess it all up.
    Thanks........
    D
    18'x33'52" Oval
    1hp 2 speed Optiflo Pump
    TA60D #325 ClearPro Sand Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: Pool Care After Major Rainstorm
    If you got a load of dirt and whatever washing into the pool, then bump the FC a little. Otherwise, you already have things figured out. Let it circulate for a couple hours before you test, to mix the fresh water into the treated water.
    I love a big rain. It means free Calcium-free water for me! But we don't get many good storms here in SoCal.
    Thanks for the reply. Very little debris and no dirt. I did get free aeration last night and with the hot days we have
    been having I was needing to add fill water to the pool any way. At least, it got done naturally.
    18'x33'52" Oval
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    You do lose a little bit of sand each time you backwash, so when I have to raindrain, I use the waste position. Most times, I don't even run the pump, just let it gravity drain.
    After all the heat we've had here, I was hoping for a good rainstorm, but it didn't happen - I'll be using the hose to fill it back up. Consider yourself lucky!
    Dan
    16' X 24' Wilkes Pools "Genesis", 10K Gal
    Hayward Powerflo Matrix 1 hp, & 18" Pro Series sand (S180T)
