Results 1 to 8 of 8
Thread: Simple pool bonding question,
    Jun 2012
    connecticut
    17
    Do you guys think that its safe to undo one of the nuts that hold the walls together in the pool that is already filled with water in order to slip the copper wire in between ?
    Thanks....
    13k Gal all resin St tropez ABG
    Clean and Clear Pentair filter
    1hp 2 speed hayward matrix pump
    CompuPool CPSC36 SWG
    Build 7/15/12
    22,544
    Re: Simple pool bonding question,
    It all depends on the design of the wall joint. If it's a typical joint that has dozens of bolts, it's safe to undo one of them. The only potential problem is getting the nut back tight. There's a possibility that the bolt will spin before the nut gets tight, but there are ways of handling that if it happens. Also you shouldn't just put the wire under the nut. You should use a bolt-on lug designed for bonding.
    Jun 2012
    western NY
    1,559
    You need to use an approved lug to connect the bond wire. In most areas the requirement is for a direct burial lug.
    http://www.cesco.com/resources/blosm/im ... 3.ext.jpeg
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2012
    connecticut
    17
    Quote Originally Posted by danpik
    do you think something like that would do ?
    http://www.lowes.com/pd_47514-12704-770 ... facetInfo=
    Thank you .
    Build 7/15/12
    Jul 2011
    Hagerstown, MD
    30
    Veetek20,
    The one you referenced is what I used on my above ground pool. It passed inspection for me however, your requirements may be different in your area.
    Thank you,
    Marvin
    24' x 54" Aqua Leader Influence Above Ground Pool
    Hayward Pro Series S180T Sand Filter w/Zeobrite
    Hayward Power-Flo Martix SP1592FP Pump
    Lamotte ColorQ Pro 7 Test Kit
    Aquabot Pool Rover Jr. Pool Cleaner
    All equipment is hard plumbed
    22,544
    The one you referenced should be fine. That's what I commonly see.
    Jun 2012
    western NY
    1,559
    Quote Originally Posted by veetek20
    Thank you .
    My advise would be to ask your inspector what they like to see in your area. Here, my inspectors want direct burial lugs even if they will remain above ground. They have markings on the sides to indicate this. Your area may allow that type of lug but, it may not be rated for outdoor or direct burial use.
    Jun 2012
    connecticut
    17
    Thanks for all your help guys.
    Build 7/15/12
