Results 1 to 7 of 7
Thread: Pool is filling with Water - What is next AGP
    Jul 2012
    Caddo Mills, Tx
    33
    I started filling my pool with water last night (city water, but is very hard, and leaves stains in commodes) and reading instruction manuals on setting up filter pump and SWG. I quickly learned that I needed sand and salt. I came back to TFP website and decided I best do some more reading. I've been up all night cramming in Pool School and also reading through the forums. This is where I am at:
    Ordered Test Kit online - TF-100 I believe it is called (along with $120 in optionals)
    Have plan to go buy 100 lbs of sand and according to Intex manual:
    360 lbs of Salt (seems like alot)
    3.6 lbs of CYA
    I thinking I needed to place CYA in sock, add all the salt, and throw in many gallons of bleach to start my pool, while only running my sand filter for the first 24 hrs? My test kits will take 2-3 days. I figure I can by the HTH 6 one at Walmart on my trip to start testing after the first 24hrs. Post the results and go from there?
    Any advice or corrections to my plan would be much appreciated. I understand I need to use the Pool School Calculator and put my results in as I can, but I won't even know the CYA for a week, so that is were I get stumped.
    Thanks in advance and thanks to this website! Without it, my Intex manuals referred me to pool supply stores for advice.
    Shawn
    14,362 gallons - Intex Rectanglar Ultra Fame 32'X16'X52" ABG
    Model SF20110 Intex Sand Filter Pump (Max Working Pressure 50 PSI, Max Flow rate: 2650gal/hr)
    With An Intex Krystal Clear SWG Model CS8110
    Caddo Mills, Tx (20 miles East of Dallas...temps low 20s to 110)
    [b]July 19, 2012 Intsall[/
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Pool is filling with Water - What is next AGP
    Don't know about the specifics of Intex but I can say that reading pool school, ordering the test kit and using the pool calculator is exactly what you want to do. Those 3 things are very important, great job
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Just a few notes - since you are going to be using a SWG, you'll want a higher CYA and will need about twice the amount listed.
    Also, I don't think it won't be "many of gallons" of bleach the first day. You'll want to dose up to about 3, which is 89 oz. For ease, I'd just add one of the 96oz jugs of bleach. You may need to repeat this a few times before your SWG is ready to take over.
    <<Please do not plan to put your results in your signature. I believe there is a 5 line limit. Also, we will need it in the thread so that we have a running record of all your test results. If it is in your signature, we will only be able to see your current results and any history will be erased.>>
    Good luck!
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    Jul 2012
    Caddo Mills, Tx
    33
    Got it! Twice the amount of CYA, 1 bottle of bleach to start off with. Did the amount of salt sound correct? Do I want to put all the CYA in at once? Two socks? And I corrected signature. Thanks!
    Shawn
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    I'm not certain on what salt level your SWG wants. According to the calculator, that should bring you up to around 3000ppm, which seems to be a pretty common figure. It will probably end up taking over 8lbs of stabilizer. If your gallons are correct, 8 lbs would get you up to 67. The suggested number in pool school for a SWG is 70-80, but it is always better to shoot low and add more, than to add too much. And yes, I would put all the CYA in at once and squeeze the socks when you can. It may end up that you need one more bag of salt. I've seen people suggest to add 200-400 ppm more of salt starting out and also to have some on hand to replenish the salt, but I will have to defer to someone with more SWG experience than I have to confirm that.
    ~~ Allison ~~
    Jul 2012
    Caddo Mills, Tx
    33
    Thanks again.
    Shawn
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    I just turned up my pool with SWG (15000 Gallon)
    I added 8 40lb bags of salt. (320lb) My SWG is green and happy
    So the amount you listed sounds about right
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
