Results 1 to 9 of 9
Thread: BBB method working, but not using borax or baking soda.
    Hello all. I have been lurking for 3 months now and with your wonderful help have installed a 24'x54" sharkline matrix pool. I have 1.5hp hayward 2 spd pump and have been running BBB from day one. My question is. I have only added 12.5% bleach to the pool and raised the CYA levels to 30 ppm... That is IT! Am I doing something wrong? I have the Taylor kit recommended on this site and my PH has always stayed balanced from 7.7 to 7.5, my TA was 90 last time i checked. The water is nice and clear. Should I be adding any other chemicals?
    Thanks for you help everyone!
    Test results
    FC 3
    CC 0
    CYA 30
    TA 90
    PH 7.6
    South Central NJ
    3,192
    Re: BBB method working, but not using borax or baking soda.
    Your fine.
    Scott
    Owner of - PoolGuyNJ LLC
    Apr 2012
    SW Ohio
    456
    Looks good....but I don't believe you without pics.....lol....we love pics
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Some people are lucky. My pH has stayed around there also but my TA is high and as I have tried lowering it I think the pH is starting to rise a little more but I'm not sure yet if this is a trend or not. The amount of aeration you get (kids playing splashing, fountains, slides) can impact the pH. More aeration = higher pH... so watch to see if over time if the use pattern of the pool changes if you need to adjust then.
    Sounds like you are doing great so far.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    Same here. Bleach and acid, and trichlor pucks when I'm on vacation. Never added borates, never needed baking soda.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Borates is kind of a personal choice item if you do not need them for raising pH. They can impact chlorine consumption, and many like the feel it gives the water, along with a little extra sparkle.
    It sounds like you have things pretty dialed in though, and may not want to change a thing right now.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I would have to agree. I am very happy with my BBB pool. Last year was swamp city.
    This year: Bleach, CYA, Some Borax for PH adjustment and some more later for purty, MA for small PH adjust and the PH for the "purty" Borax. I only added a small amount as the dog drinks some of the water.
    This is how the kids like it!
    -- Guy --
    Quote Originally Posted by techguy
    Dog on the raft! Awesome!
    Plano, TX
    20,000 gallons Kidney Bean IG Plaster, Pentair Clean and Clear 530 Cartridge Filter
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Kriv, I have dog on raft barking at squirt guns video on my YouTube I will round up a link.
    -- Guy --
