Thread: Richard's Pool School
    Jul 2012
    Riverside, CA
    51
    I'm reporting back as Richard's grateful student. He came over to my house this afternoon and spent 3 hours educating me, a pool dummy!
    He patiently mapped out my circulation system, which is a total maze with three pumps and LOTS of mysterious valves. He showed me his fancy speedstir test kit and generated the following results:
    FC: 0
    CC: 0
    TC: 0
    pH: 7.4
    TA: 130
    CH: 600
    CYA: 130
    The pool water is clear. Plaster shows a bit scaling.
    My pool recently had an algae breakout and just went through Leslie's Yellow Out process. During the process I put in their Yellow Out algaecide, and shocked the pool with 9 lbs of Leslie's Power Powder Plus, and finished with 10 capfuls of Pool First Aid. But yellow algae is still visible. Richard even spotted some green stuff in the skimmer opening.
    Richard suggested water replacement or reverse osmosis to reduce the CYA. Till that's done, I need to keep putting in chlorine to prevent the water from getting worse.
    Thank you, Richard, for such great schooling! Oh, and thank you for saying I was not fat even though I was too buoyant to touch the . pool floor.
    20,000 gallons, IG plaster, probably built in the 80's.
    Filter: Hayward Pro-Grid DE6020, 120 GPM.
    Pump: Magnetek century E-plus, Purex Triton Whisperflow, WFE-4C, 1HP.
    Fountain booster: Century Centurion A O Smith, CAT B848, 1HP.
    Spa booster: G.E. Jacuzzi pump
    Heater: Raypak RP2100 Digital, Low Nox
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Richard's Pool School
    Good luck!
    Let us know if you do a "dump and fill" or an RO, and we like pictures.
    -- Guy --
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Wow, can't beat that level of help...maybe he'd like a scented candle or something
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Quote Originally Posted by cramar
    OK, that there is just funny!
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
