Thread: Available chlorine vs sodium hypochlorite
    Jun 2010
    Rural Southern Illinois
    49
    So my normal supplier of pool shock switched brands and instead of 10% sodium hypochlorite on the old brand, the new brand says 15% available chlorine and 12.5% sodium hypochlorite. My guess is I need to calculate using sodium hypochlorite, but I wanted to ask to be double sure.
    On the bright side, the price I still the same, 4 gallons for $9.99!
    Thanks as always for your help!
    17100 gallon 27' Round 4' Deep Above Ground Pool
    Hayward Cartridge Filter 1 HP pump 50 GPM flow rate
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Available chlorine vs sodium hypochlorite
    Pool Calculator will let you plug in 12.5%. It also has that as one of the choices on the drop down menu.
    Mar 2007
    San Rafael, CA USA
    12,082
    As Richard says, put in 12.5% into The Pool Calculator, but their 15% Available Chlorine can't be right. The following relationship is usually true:
    % Available Chlorine (weight % of chlorine) < weight % of sodium hypochlorite < Trade % of chlorine (volume % of chlorine)
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    And $10 for four gallons of 12.5% is excellent
    good for you!
    Dan
    16' X 24' Wilkes Pools "Genesis", 10K Gal
    Hayward Powerflo Matrix 1 hp, & 18" Pro Series sand (S180T)
    Menards has that same price right now, too bad it isn't the regular price! I pay $13 for 4gal of 10% which was only $11 last year.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
