Results 1 to 11 of 11
Thread: Skimmer making gurgling sound
    Jul 2012
    Toulon, Illinois
    43
    I just got my pool up and running a few hours ago. I went out to empty the skimmer basket before bed and I noticed it has a really good "tornado" in the skimmer and suction is good but its making a gurgling sound. Is that normal? As many of you know, I'm new to the pool world.
    21 foot by 4 foot AGP, Jacuzzi Laser 192 sand filter, Hayward 1 HP pump, approx. 9100 gallons, install 7/15-7/17/2012
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: Skimmer making gurgling sound
    It means either the water level is too low or the weir (flapper) is sticking.
    Jul 2012
    Toulon, Illinois
    43
    Water level is at about the middle of the skimmer opening. There is no flapper, when I take the skimmer basket out I can stick my hand down to hose. There is also no flapper on the front of skimmer. Doesn't look like it ever had one.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Does it do that with the basket in?
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Jul 2012
    Toulon, Illinois
    43
    Yes it does Vette.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Doh! I meant basket out.
    Jul 2012
    Toulon, Illinois
    43
    Yes both in and out.
    30,419
    So you have one skimmer, right? The pump basket must be full of bubbles and turbulence right?
    You will need to slow your water down if that's the case. can you post a pic of the equipment pad so we can see if there are any control valves or a place to put one.
    (No, it is not normal )
    May 2011
    Clearwater, FL.
    446
    Hi again SadieBailey,
    The weir door is missing? That will for sure do it. Fix that first, my skimmer box has 2 small holes at the bottom of the inlet at the gasket, this is where the weir door clips in. (Hayward brand)
    Try and find something plastic or stone that's very flat and try and mount it in the basket standing up to stop the swirling until you get a weir door.
    Try one more size smaller eyelet in your return(s)
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Jul 2012
    Chicago, IL
    356
    ahh, well that explains my problem! I experienced this as well, there was a very thin whirlpool being created (called a vortex I learned) that would go all the way down to the basket and make an obnoxious sucking sound, even though the water level in the skimmer stayed pretty high. Putting a stone in there solved the problem so I just assumed that my pump was too strong, but thanks to this thread I learned that my skimmer is supposed to have a door!
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Jul 2012
    Toulon, Illinois
    43
    Me too Paula, I love this site!
