Thread: Crack from skimmer
    Crack from skimmer
    Repairing crack in pool side will from skimmer down about 5 feet. Do I need to inlay support like rebar or Torque-bar, or will an epoxy fill suffice?
    30,432
    Re: Crack from skimmer
    I'd reinforce it with rebar. it will still move and the epoxy will not be able to stop that.
    I wonder if anyone has tried to put post tensioning cables in a pool shell?
    Blaine
    50' x 22' 27k gal shotcrete freeform, 2hp 2 sp Pentair Whisperflo, Pool Pilot RC-52 SWCG, Pentair TR 100 sand filter, Prowler 820 robot, Florida Sunseeker LED lights.
    My pool build:
    osage-hills-pool-build-t50526.html
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Quote Originally Posted by bpricedo
    That would be... Difficult. The only parts you could really post-tension are the bond beam in a rectangular pool and no parts of a free-form. You can only put tension on a straight cable, If the cable path is curved it would rip the shell apart.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
