Thread: OCLT timeframe
    Jul 2012
    South Carolina
    48
    OCLT timeframe
    Out for the evening and it rained. Tested FC and needed to add some. Did so. Now, it's 11 pm. I'll need to get water sample at 6 am....7 hours from now. Is that enough time to determine if I've lost less than 1 ppm?
    15 K gallons
    Gunnite
    Centurion Pump/Hayward Sand Filter
    Polaris 360 Robot
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: OCLT timeframe
    Should be, but you need to wait for an hour with the pump circulating after dosing to get your evening number.
    Jul 2012
    South Carolina
    48
    Re: OCLT timeframe
    Thanks...was going to wait 30 mins bc I read that somewhere on here, but I'll do the hour to be sure. Am I correct to assume if it rains overnight, this test is invalid?
    15 K gallons
    Gunnite
    Polaris 360 Robot
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: OCLT timeframe
    Probably, though if you pass, it still should be valid, but if you fail, then I would redo tomorrow night.
