Thread: Pool Opening and 60psi on sand filter
    Jun 2007
    Boise Idaho
    58
    I just opened my pool and can't figure out why my sand filter is running pegged at 60+psi. I opened the sand filter to find plenty of sand in the tank. I backwashed gallons and gallons of water.... and the glass monitoring tube showed clean water.
    When I shut the pump off the sand filter gauge says around 48psi....never going to zero.
    This hayward sand filter is less than a year old. Any ideas of what I might try next?
    __________________________________________
    18x36 inground, sand filter, sta-rite sr400 ng heater
    Mar 2008
    Maryland
    56
    Sounds like you need to replace the pressure gauge. Cheap and easy fix.
    Jun 2007
    Boise Idaho
    58
    Thanks, that's exactly what it was. Took it off and it still read 50psi.
    Just picked up a new one for $13.
    Thanks!
