Thread: According to pentair's website this system turns 28,800 gal.
    Jul 2012
    NE,OHIO
    13
    I have a 11,500 gallon above ground pool and my pump/sand filter system is a 1 1/2 hp cristal flo ll. And according to pentair's website this system turns 28,800 gal. in 8 hrs and 36,000 in 10 hrs. I'm not sure if they calculate for restictions, but that should be plenty of turnover in less than 10 hrs right?
    21'x52" Asahi Fijian AGP 11,000 gallons, sta rite 1 1/2hp pentair pump, 60 gpm, 250# cristal flo 2 sand filter with zeolite media, foam cove, DIY finished in 7/12
    38,354
    Re: Ideal turnover rate
    Turn over and flow rate do not matter. You only need to run your pump long enough to keep the water filtered to your liking. Some members only run for 4 hours per day ... others run on low speed for 24 hours per day. It is all a matter of personal preference.
    Jul 2012
    NE,OHIO
    13
    Thanks, Jason
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    I've found that other factors (solar heating, SWG, heating efficiency, skimmer performance, energy rates, preferred swimming schedules, outdoor noise tolerance) have determined pump run times and minimum flow rates, and then just adjusted actual flow rate to be > min and sufficient so that water is turned over at least once/day and that there is at least a few hours of daily high speed filtering to clear the surface. For newer variable speed pumps, running the pump for longer at lower flow rates can reduce both pump noise and energy costs substantially.
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
