Thread: Pump Broken
    Pump Broken
    So our pump broke down last night and dropped it off to get fixed. The question I have is while we have no pump and filter is there anything special I should do with the pool to keep it in ok shape? Also can we still use it? Or will that just make it harder to keep it in good condition? It is an above ground pool. Thanks
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: Pump Broken
    Use your pool brush a lot to keep the water moving. You can still use it if your chlorine levels are within the proper range for your pool's CYA level.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Pump Broken
    Add your chlorine and use something to stir it in the pool... canoe paddle, brush, neighbor's kids...JK. You might need to break up the amount you add at a time if you are using human stirrers. If you have a sump/trash/submersible pump, you could add to the pool while the other one is in the shop to keep the water flowing.
    -- Guy --
