Thread: First results with the TF 100
    CL 16
    CYA 55
    TA 110
    CH 360
    PH 7.4
    According to the pool store I also my phosphates are 1000
    I had my aqualine chlorinator set at 24% which is clearly too high. I dialed it down to 15% in an attempt to find the sweet spot. I have a vinyl pool, how troublesome is the Calcium Hardness?
    How low do I need the TA to be to stop the requirement of muriatic acid every three days? Thanks.
    16 X 32 Vinyl. Hayward aqua rite salt system, T -15 cell. Hayward H250 gas heater, Hayward 1HP superpump.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: First results with the TF 100
    Quote Originally Posted by jonmar
    Ignore phosphates. If you keep your FC at the appropriate level, then phosphates do not matter.
    Our recommendation for swg's is 60-80 ppm TA which works for most pools. See: http://www.troublefreepool.com/pool-...ater_generator
    Generally not a problem though high CH combined with high TA and high ph in some cases can cause scaling and cloudiness.
