Results 1 to 7 of 7
Thread: 20 lbs of chlorine pucks!
    Jun 2012
    central coast CA
    7
    Hello to all wonderful patient members!
    just getting started with bbb method. just received my new test kit! ok, do I use up my pucks (bought before I found TFP and the BBB method)?
    15,000 gallon kd 16x33x42 AG. Sand filter TF 100 test kit
    BBB method
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: 20 lbs of chlorine pucks!
    I would NOT... but don't throw them away... they can be used while on vacation.
    Now... open the plastic and let's see your numbers!
    -- Guy --
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    get us a full set of numbers with that new test kit, and we can tell you whether to use those Pucks now or later. If your CYA is low, using the pucks would be no harm.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Jun 2012
    central coast CA
    7
    Cl. 0
    Ph. 7.5
    Cya. 0
    BBB method
    Vette's Avatar
    Jul 2012
    Ohio
    404
    You need chlorine in your pool. Is it a new pool? You can use pucks to add CYA, or buy stabilizer to add it. You need it if it truly is 0.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Jun 2012
    central coast CA
    7
    Added 2 floaters of pucks and 2 jugs of chlorine, oh, and 2 cups of cya through mesh screen floating
    BBB method
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Looks like a good start. The CYA may not show up in tests for about a week, but assume you have when using the pool calculator. No real need to test for it much before then.
    -- Guy --
