Thread: Adding cya
    Jun 2012
    central coast CA
    7
    Adding cya
    Should I mix my cya with water in a bucket before adding to pool? New fill not sure how ,any ounces to start with added 2 bottles of bleach and plan to do my first test after adding cya
    Thanks!
    15,000 gallon kd 16x33x42 AG. Sand filter TF 100 test kit
    BBB method
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: Adding cya
    Is it liquid CYA or solid?
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    38,271
    Re: Adding cya
    Use poolcalculator to calculate how much CYA and bleach you should be adding.
    Solid CYA should be put in a sock and hung in front of a return. The liquid can be added to the pool as you describe.
    Note that the solid CYA may not show up on the test for a week, so no point in testing it now.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Adding cya
    Attempting to dissolve CYA is in a bucket will result in white pearls sitting in a water bucket for much longer than you thought they would be there.
    Dissolving them in the sock in the pool is the best way. They dissolve very slowly in the absence of a strong flow.
    -- Guy --
