push/pull valve
Jul 19, 2012
5
I have a sand filter that has a push/pull valve on it and have an algae problem,any chem. to use to get rid of it calls for vacuum to waste,but I don't know if I can do that with this type of valve,cause as far as I can tell it is either in backwash mode or filter mode an6y ideas ?
Hi, John. Welcome to the forum. :lol:
Yeah you cannot vac to waste with a push/pull but you'll still be ok.
Simply start vacuuming up all the junk on filter and when your filter psi rises 20-25%, backwash and start over again.
Reactions: Aznewmom
