Thread: Switching flow direction on Intex SWG
    wondering if anyone has removed the intex swg tube that the water flows through and spun it 180 degrees and put it back on?
    my swg doesnt sit right up against the pool, it is off to the side along the fence and the way everything is hooked up the SWG is facing the fence.
    asuming the cords are long enough i think i can just unscrew the tube and turn it around and screw it back on so the display is facing me instead of the fence.
    Any thoughts?
    My pool:
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter
    Jandy Laars LX400 propane heater w/120 gal above-ground tank
    Jandy AquaLink RS OneTouch controller w/PDA remotes and computer control
    JVAs control pool/spa switch and also allow drain opening
    Hayward Navigator
    22,552
    Re: Switching flow direction on Intex SWG
    As long as you don't make it so the flow switch won't work you should be fine.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Hm, mine is backwards too but I have enough hose to have it face out but it's not optimal. I may look into spinning the tube on mine now that you brought it up. According to this Intex picture it looks like 4 screws hold the tube down and it could be spun. Not sure if the cables are long enough to allow this though. Worth a try. Water still needs to flow the direction of the arrow on the tube.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    I just switched it with no problems at all!! The only one that may cause a problem would be the line for the copper,but I have it unplugged anyways.
    My pool:
    Hayward Navigator
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Cool, I don't have the copper part because mine is an older unit. I'll have to do this. Thanks.
    Mike
