Results 1 to 11 of 11
Thread: First test with my new Taylor k-2006
    Jul 2012
    Chicago, IL
    358
    I've been relying on the strips for the past month and I finally got my taylor k-2006. I've had zero problems with the water thus far (pump is another story!), I am guessing because the pool is not heavily used and I've been pretty diligent with testing and vacuuming. With the exception of the first few days of opening (4 weeks ago), I've added no chemicals other than chlorine.
    If it is relevant the chlorine I use is the pucks from a 40 pound package I got from Costco, though I plan on switching to BBB once I run out.
    Test results:
    FC 3
    CC 0.5
    PH 7.4
    CYA 40
    TA 110
    Calcium 170
    Everything seems pretty well in line, right? Maybe a bit more chlorine is in order....
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Feb 2012
    Phoenix, AZ
    728
    Re: First test with my new Taylor k-2006
    Those levels look good. You could stand to have a little higher FC, but are within the recommended range!
    Keep in mind that those pucks will be adding CYA. You CYA level of 40 is fine, but you won't want to raise it above 50. How many pucks do you have left? You can use pool calculator to find out how much CYA the rest of your pucks are going to add. If you have a lot of pucks and it will put your CYA over 50, you might want to switch to a different chlorine source before you run out of pucks (and you could save them for later).
    Jul 2012
    Chicago, IL
    358
    Thanks Blake. Oh man, I have a TON of those pucks, bought a 40 pound container about two weeks ago. I think I will migrate to bleach and use the pucks intermittently if CYA drops as you suggest.
    Feb 2012
    Phoenix, AZ
    728
    Sounds good. Just know that CYA will NOT drop on its own...it will only go down with water replacement or a process called reverse osmosis. You can, however, use the pucks if you are going to be away from your house/pool and don't have anyone to maintain your chlorine (like a vacation).
    Jul 2012
    Chicago, IL
    358
    How do I use the pool calculator to figure the number of pucks I can use before my CYA gets too high? I couldn't see how to back into the number. Or maybe a better question - is the number more like 2 or 20? Reading of others troubles on this makes me want to stay far far away from high CYA.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Each puck will raise CYA by about 1.7ppm. You've got room for maybe 10 ppm. 6 pucks.
    Jul 2012
    Chicago, IL
    358
    Thanks Richard. I used two pucks over the weekend so my margin of safety is shrinking. I will throw some bleach in the pool tonight, my first foray into BBB!
    38,539
    Quote Originally Posted by Pauls234
    On the poolcalculator:
    Set your pool volume at the top.
    Then toward the bottom there is an area called "Effects of adding chemicals" select trichlor and then put in the weight of a puck (7-8oz typically)
    Or set your Now and Target CYA values in the middle and see how much weight of trichlor would get you there. Then divide by the weight of your tablets.
    What do they say about teaching how to fish
    Those tablets will keep just fine, save them for vacations. You may find that CYA declines over the winter due to excessive rains or snow. I exit most winters with low CYA which I savor, banking it for upcoming spring vacations.
    I suggest that you look at the container very carefully for any indication that those pucks are special in any way. Some of those products that are 3-way or whatever may add copper algaecides to the pool. If you have copper you certainly want to know that. Just trichlor and stabilizer is fine.
    Jul 2012
    Chicago, IL
    358
    Jason - thank you! I definitely want to learn to fish, or as was the case here, to simply scroll down!
    Anona - I like the idea of banking CYA room, as a new pool owner, those pucks sure are low maintenance. I checked the label, it says ~94% tricholor----[some long chemical word] so seems they don't have other stuff in them.
    Speaking of CYA, I'm questioning my test results. Not the testing kit but my interpretation, but this probably deserves its own thread.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    You can post your questions here, keeping it all in one thread is helpful for others to see your history. You can pour and re-pour the CYA a number of times to see what your average is. Do the test with your back to the sun, hold at waist level and pour till the black dot disappears (no hint of it).
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
