I would have to raise the FC to about 30
one more thing for your sig... type of surface? vinyl, plaster, fiberglass? Above or in-ground pool? We also assume outdoor. What part of the world do you live. I know...1,000 questions but it all makes a difference to how to manage your pool.
Morning log :)
FC dropped by about 1ppm overnight but likely less if done a 25ml drip test
No CC evident
Pool so crystal clear.
Yeah! :)
I will leave SWG off until FC comes back down to 5, with this hot weather my guess that will be about 3-4 days.
thanks guys.
Michaelandliz said:
Signature now modified with all info to hand.
Thank you!
Michaelandliz said:
2nd line down it says liner and 17,000 gal so would be inground ;)
33'X48" agp's are ~26000 gallons, so high volume does not imply inground :wink:
Was is less than 1 ppm or not? i.e. did it take two drops to change to clear, with the third drop making no change? We are sticklers here on this since we have experienced situations where "close enough" ended up being not close enough :|
