Thread: Want to learn more about BBB method
    Hello, I was referred to this site by a friend. I live in Lynchburg, VA. My pool is 25,000 gallons, below ground, built in the early 80's. It has a vinyl liner, 1hp pump with 3450 rpm and 56j FR. It has a sand filter and the water is clear right now. I am interested in the BBB method to save money. My test results are as follows, TH, TC, FC, BR, stabilizer, are all very low. The ph is 7.2. I have been using chlorine tablets and powder shock and baking soda. I need advice on how to treat my pool. Thanks, Jared
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Want to learn more about BBB method
    Hi, welcome to TFP! In order to help you we need to know the actual test results. Just saying they are very low doesn't give us enough information and most of the advice we give is based off of test results. If the tablets and shock you use are dichlore/trichlor then your CYA may be much higher than you think. Do you have a test kit or do you use strips?
    Love TFP? Become a
    TFP Supporter!
    Vette's Avatar
    Jul 2012
    Ohio
    404
    We need numbers for your chemical levels! The first step is to get a reliable test kit that you can use to test yourself. By FAR the most recommended kit here is the TF-100 kit at tftestkits.net, but any of the kits they sell work. You need to read pool school as well. The link is in the top right of this site, a big button that says POOL SCHOOL. Read it all, twice! That will give you a lot of knowledge.
    And remember, BBB is more about the knowledge than the chemicals. It's nice to know what is going into your pool (and be able to mix and match your BBB knowledge with pool store stuff). For example, I use "PH Increaser" right now. Sure I know its Sodium Carbonate, but I got a good deal. But because of BBB, I was able to test myself and figure out, "oh, my PH needs a bump up" and was able to select the right chemical easily without having to go through a chemical sales pitch. Without BBB and TFP, I'd be getting my water tested at a store and dumping PhosFree in my pool all day.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    30,413
    Don't do it for that reason. You will likely save money as sort of a side effect but the reason to learn BBB is because you want to be in control of your own pool.
    If that is what you want to do, then read "The ABC's of Pool Water Chemistry" up in Pool School as a start and continue to read the other articles.
