Thread: CYA level with SWCG
    Aug 2007
    Southern California
    9
    CYA level with SWCG
    Quick question. I've read to check the manufactures suggested CYA level for CYA when using a SWCG, but mine (Polaris Autoclear Plus) says to check local requirements. So is it necessary to have CYA at all when chlorine is being generated daily?
    I'm currently trying to lower the PH in the pool with MA, and I read that adding CYA will raise PH.
    Here's my test results for today.
    FC-3.0
    CC-0
    PH-8.0
    TA-125
    CH-325
    CYA-0
    Thanks again.
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    30,432
    CYA will make no really significant change in your pH.
    I have no idea what your local requirements for CYA are but most SWG's, as you know, suggest 60-80.....that's what I'd do.
    Yes, it is necessary to have CYA. Chlorine still needs protection from the sun regardles of the source.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Soalpool,
    Here is a Stickey by Waterbear on water balance tips for a SWG:
    http://www.troublefreepool.com/sticky.php?s=3663
    Hope this helps
    You're done SLAMing when:
