Thread: Converting intex pro series 24 ft filter/pump to sand filter
    Ok...so I have read a bunch of posts here but really not pin pointing the answer...is there a fitting to go from a skimmer to a sand filter...I have the metal frame 24 ft intex pro series and as a bonus the lovely pumped died....so I picked up the intex sand pump/filter-1600 gph...another surprise is everything works great...kind of...right now the pump sits 2ft off the ground with the intake weighed down at the bottom of the pool...soooo the water level is below the skimmer line...anyone know of a simple way to connect the sand filter to the bottom of the skimmer? Please help...desperate me...
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Converting intex pro series 24 ft filter/pump to sand fi
    Have a read through this thread.
    summer-escapes-pro-series-13-x22-rectangular-questions-t43440.html
    You will find a link to an adapter in one of the posts. I could have given the link to the adapter but I thought you might benefit from reading the thread.
    And this
    cutting-a-liner-for-new-intake-and-return-with-pics-t48197.html
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
