Results 1 to 9 of 9
Thread: Calcium hardness
    Jul 2012
    South Carolina
    48
    Calcium hardness
    My current readings
    FC 3.5
    CC .5
    TC 4
    PH 7.2
    TA 50
    CH 130
    CYA 40
    Plaster material has shown up in our vacuum bag. Do I need to go ahead and add calcium? Will that prevent this for happening? What about alkalinity. Fix that at the same time?
    15 K gallons
    Gunnite
    Centurion Pump/Hayward Sand Filter
    Polaris 360 Robot
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Calcium hardness
    Yes. you need to fix pH, CH, and TA. If you plug your numbers into Pool Calculator, you'll see that CSI is waaaay too negative, -.87 @84F.
    Jul 2012
    South Carolina
    48
    Thanks for the quick reply...
    According to the pool calc...
    Add 15 oz washing soda to bring pH up to 7.5
    Add 176oz baking soda to bring TA to 100
    Add 289 oz calcium chloride to raise CH to 260
    Do I put all these things in at once?
    Figures sound on target?
    15 K gallons
    Gunnite
    Polaris 360 Robot
    38,364
    The baking soda will have some affect on the pH ... and the washing soda will have some affect on the TA.
    I would suggest raising the CH to 300, TA to about 80ppm and pH to 7.5
    The CH can be done any time, but I think you are best to adjust the pH before the TA ... note that the changing 1 affects the estimates of what you have to add to change the other.
    Jul 2012
    South Carolina
    48
    What do you think is the most cost effective place to purchase the calcium?
    15 K gallons
    Gunnite
    Polaris 360 Robot
    Richard320's Avatar
    Jan 2010
    19,037
    Numbers don't look quite right. I think it went to the default 10,000 gallons, not your 15000. I'd work things one at a time, as Jason said. pH first. Do it when you have time to brush the pool to mix things. And probably give things an hour to mix, if not more, before retesting and adding the next.
    38,364
    I think you had the #s correct ... I have 15k gallons set and see the same quantities.
    Jul 2012
    South Carolina
    48
    Redid the numbers....you were right....the amount of calcium needs to be much more.....
    Just added some ash to bump the ph a bit
    Any suggestions on where to get the calcium? The evil pool store?
    15 K gallons
    Gunnite
    Polaris 360 Robot
    Jul 2012
    South Carolina
    48
    Thanks for checking on me jblizzle...
    15 K gallons
    Gunnite
    Polaris 360 Robot
