Thread: Arm and Hammer Super Washing Soda vs. Borax
    Jul 2012
    South Carolina
    48
    The local walmarts around here have been out of borax for a while. Does the A&H super washing soda do the same thing? Is this what the pool calculator calling 'washing soda'? This says sodium carbonate on box.
    15 K gallons
    Gunnite
    Centurion Pump/Hayward Sand Filter
    Polaris 360 Robot
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Arm and Hammer Super Washing Soda vs. Borax
    These are not the same thing. Super washing Soda will raise your pH, but will not increase Borates in your water. If your motivation for using Borax was strictly to raise pH, you can use the Washing Soda, but make sure to input the right data on Pool Calculator. If you are trying to get Borates in your water, wait and use the Borax, along with any Muriatic Acid needed to control the pH rise.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Sodium Carbonate is sold by pool places as PH Increaser! It certainly works!
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    38,364
    sodium carbonate = washing soda = soda ash
