Thread: Just getting started
    Jun 2012
    Cinnaminson NJ
    102
    Other than absorbic acid, are there any metal sequesrriants that'll take copper stains off walls? I know aa does it quick but too many side issues come with it. I know the main use of sequestriants are too prevent stains but once they're starting I would like to use something other than aa even if it'll take longer to see results.
    Southern NJ, 1 HP Haward Pump, 16x 32 dimensions, 21,000 gallon vinyl liner inground pool, TF-100 test kit.
    Re: Just getting started
    Ascorbic acid is not a sequestrant, it is a stain remover. Stain removers lift stains off of surfaces. Sequestrants bind to metals in the water and prevent them from forming stains. Sequestrant will occasionally help remove a stain from a surface, but that is not it's primary purpose.
    Ascorbic acid has the fewest "side issues" of any of the stain removers. If it works it is either the same or simpler to use that anything else.
    Removing copper stains in particular is unpredictable. Sometimes they come off fairly easily, other times they can be very difficult to remove. Copper can take several different forms, each of which responds differently to stain removers.
