Results 1 to 7 of 7
Thread: combined total free chlorine
    Jul 2011
    S.W. Ontario, Canada
    23
    I am a little confused over Total Chlorine, Combined Chlorine and Free Chlorine
    The HTH 3 way test kit to my knowledge, measures Total Chlorine
    My test strips measure only Free Chlorine
    I currently have no way of measuring Combined Chlorine.
    It is my understanding that Combined Chlorine = Total Chlorine Free Chlorine
    So if I have free Chlorine at 2ppm
    and Total Chlorine at 5ppm
    I have combined chlorine of 3ppm and I need to shock the pool ? Even though it looks great, sparkling and clear ?
    No I dont have a Taylor test kit, im In Ontario Canada and they are next to impossible to obtain.
    2012 new 15' x 52" round sharkline above ground, DIY installed & BBB maintained. 3/4hp with 19" 150lb sand filter, 4 x 20 sungrabber solar heater. DIY solid piped.
    Re: combined total free chlorine
    You have the right idea. However, if you are getting FC and TC from two different test kits, the errors in their readings won't be correlated, so the potential error in the CC result will be much larger than it would be if you got both numbers from the same test kit. To put that another way, chances are than one or the other test result is wrong, and thus you can't trust the CC result you get that way.
    Aug 2010
    Dallas, TX
    4,052
    Are you sure you can't find the K2006 in Canada?
    TC=FC+CC
    Perform the overnight chlorine loss test and you'll know if you have a problem.
    pool-school/overnight_fc_test
    38,524
    This is where I have heard the neighbors to the North have to go:
    http://piscines-apollo.com/cubecart/tes ... -2006.html
    Of course they are out of stock
    Jul 2011
    23
    Did not use the pool yesterday and neglected to check it.......
    This morning, Total Chlorine and free chlorine are both at zero. Which in effect is a good thing i guess.....
    Added 42oz of walmart bleach to bring it up to 4-5
    Looks sparkling crystal clear
    How long before water goes bad if FC left at zero ? im guessing a few days at least, and less as the temps go up ?
    38,524
    Algae will start to grow any time the FC is lower than the minimum for your CYA level as shown in the CYA/FC chart in Pool School. What is your CYA level?
    One of the recommended test kits would be a very good investment for you. As right now it seems like you only test for a couple of the chemicals.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    My pool went bad last season after being below minimum for maybe 6 hours. It can happen fast.
    I caught it early, and all was well 12 hours later. But I also have a test kit that tells me if something's wonky. I know it's hard to find the right kit, but it really is worth some further effort to get one.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
