Thread: How to keep FC where I want it?
    So I want to keep my FC around 6. At night when I add my bleach do I just add enough to get it back to 6 or a little more so it never goes below 6? How do I figure this out? My pool is in full sun and loses on avg 3-4 ppm per day.
    Jill
    28k gallon IG Vinyl Pool, 1hp Hayward 200 with Zeobrite in it, Full sun, no bottom drain, heater
    38,274
    Re: How to keep FC where I want it?
    What is your CYA? That determines what your absolute minimum should be. You should add bleach so that is not at the minimum the next time you test and add.
    Considering your CYA is around 50, I would just put your FC at around 8 when you pour your bleach in and let it go down from there. That's what I do...When it gets to 5 or 6 I put more in. I found that it would drive me crazy trying to get it locked in on a certain number, and since my suggested levels are between 4 and 9 it works well.
    32,000 Gallon Vinyl Lazy L
    Hayward DE6000
    Hayward Ecostar SP3400VSP
    Aquabot T4RC
    Taylor K2006
    38,274
    Quote Originally Posted by NJKen
    Do we have mind readers here now?
    This is why all questions should be kept in the same thread ... so all the info is available.
    Just a general question! Thanks, this is what I have been doing but just making sure that I'm not making things harder than they need to be!
    Jill
