Thread: Problems with water leveler (Paralevel)
    We built our pool about a year ago. The automatic leveler worked fine for a while, but then it didn't seem to be working anymore. The water in the pool was often too low. Last week, I tried to adjust the leveler and the pool filled up too high...almost overflowed. We couldn't get it to stop, so my husband turned off the water. When some of the water evaporated (it's been over 100 degrees here), I turned the water back on and now water just shoots out of the leveler itself and spreads all over the deck. I have no idea what to do. Any suggestions?
    Our Money Pit...I mean...Pool...
    is a 15,000 gallon, sand-filtered, vinyl liner-d, in-ground mess installed in 1988.
    (I'm just learning now how to take care of it)
    Apr 2012
    Klein Tejas
    249
    Re: Problems with water leveler (Paralevel)
    Perhaps when it was being adjusted the plastic nut came loose that hold the valve into the container? I think the instructions on how to adjust the paralevel can be found online.
    Pool is DONE!
    Pentair Intelliflo VS3050
    Pentair Easy Touch 8 + actuators + swg
    Pentair IntelliPH
    Pentair 400btu HD heater
    3- Jandy WaterColor LED's
    Hayward C5030 525sqft cartridge filter
    Waterway spa blower
