Thread: Under water pool lights
    I have a 12volt bulb in my two under water pool lights. I have the output of my transformer set for 14 volts. I measure 11 volts across the connections when it is connected to the lights. Is this ok or should it read higher? The bulbs are not lighting.
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    405
    Re: Under water pool lights
    I suppose you don't know if the output has always been 11volts do you?
    Longer electrical runs will see voltage drop. But since they worked before, that can probably be eliminated as an issue.
    Are you sure your not taking a reading before the gfci, and it tripped?
    16x32 Concrete IG 24k Gallons
    Equipment: Carvin 525sf Cartridge Filter, Jandy Gas Heater, Vortex Solar Panels w/solar valve, 1hp Hayward Pump with 3/4 HP AO Smith 2 Speed Replacement Motor, Aquarite Saltwater Cell, Polaris 280 Dolphin Active 20 Robot
    Automation: Hayward Prologic Controller
    May 2012
    Montville NJ
    545
    My 12 volt transformer reads 13.4 V across the leads when bench tested.
    they are pool light sources, not refrence voltage generators, I don't think the tolerances are that tight.
    With mine at 13.4 volts it lights up my 12 V bulb just fine. I have never measured what it reads with the bulb attached.
    How/when did it stop working? All of a sudden, after a period of non-use, never worked?
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    This is a 45 year old pool which I just inherited. There is no ground fault and I don't know what the load voltage was because the transformer burnt out. I replaced the transformer and had two new bulbs put in. Tomorrow I will measure the total load resistance and see if I can figure the voltage drop. I guess I should pull the lights out and see if I can measure the voltage across the bulb. Any other ideas?
    Thanks so much for your interest in this. I hope I posted this correctly since this is my first post.
    Bob
    Jun 2011
    Nj
    57
    11v should be fine
    it will run at 9v but they will be dim
    you will have a loss in voltage over your lenght of run and the gauge of wire will also effect how much of a loss
    take the bulb and put your meter on it and check for continutiy, it will beep if the bulb is good, it will not if it is bad
    or hook it up to a car battery and see if it lights
    if you have voltage at the socket, i would suspect the bulb itself
    11,000 gal inground fiberglass pool
    Aquarite SWG system
    May 2012
    Montville NJ
    545
    What kind of pool do you have? At 45 years, whatever it is, it is showing it's age.
    I know with my light, if you leave the lamp in over winter, it can be damaged (old owner did that - $50 for a new bulb)
    I pulled the power supply from the pool, and tested it on the bench (and got 13.4 V) then I ohmed out the lamp and got an open. That's when I decided that a $50 new lamp was most likely the answer (I turned out it was the answer)
    -dave
    Zodiac Wahoo
