Thread: Need to Scrub off Algae - recommend wire brush.
    Is any wire brush ok, or does it need to be a special type of wire brush?
    We have a concrete pool with tile.
    Finally have the water sparkling clear and just need to tidy up some stains.
    Thanks!
    660k Plaster Indoor
    38,271
    Re: Need to Scrub off Algae - recommend wire brush.
    Wire or dual brushes are fine for older plaster (over 1 year old).
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    If your pool is concrete with paint, I would avoid a wire brush. If well aged plaster, no problem. They make wire brushes that fit on your wall brush pole. As mentioned, they also offer combo brushes that have some wire bristles mixed in with the traditional nylon bristles.
    If wire is not the proper choice, try one of the new Wall Whale Brushes. It has a flap on the back that creates more downforce when brushing.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
