Results 1 to 8 of 8
Thread: Trying everything, but algae still remains
    I have had algae in the pool for almost a week now. I have tried yellow out after raising the ph, but it is still there. Last night, raised the ph because it lowered again, scrubbed the sides and bottom of the pool. I have put in a gallon of bleach this morning and checked it an hour later and no movement on the FC. I then added shock to the pool and still no movement.
    Any suggestions, before my husband drains the entire pool? By the way we have a 21' round pool.
    FC-0
    PH-7.5
    TA-120
    TH-200
    CYA-40
    Thanks
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Trying everything, but algae still remains
    Hi, welcome to TFP! Shock is a process and not a one-time application of product despite what the bags of shock say. You will need to raise your pool to shock level and keep it there as much as possible until you pass the 3 criteria for completing the shock process. Read shocking your pool and defeating algae for more information on the shock process.
    Love TFP? Become a
    TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    You haven't tried the shock process correctly yet.
    Assuming the pool is only 3' deep, a gallon of 6% bleach will only raise FC to 8. Shock level for your CYA is 15. If the pool is deeper - holds more water - your FC was even further from shock level.
    [center:1q0izjzy][/center:1q0izjzy]
    CYA high still no chlorine
    I have a 21' round above ground pool with cartridge filter.
    I have been having problems with getting rid of algae in the pool. I have been adding borax to get the ph level and that has worked. I added stabilizer last night in hopes to see a chorine level. I have also added a gallon of bleach to help with the chlorine. As of this morning here are my levels.
    FC-0
    PH-7.2
    TA-100
    CYA-120
    Should I add a ton more bleach to get a chlorine level or should I drain some of the pool and add fresh water?
    Thanks
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, she1021
    Please keep all your posts in this thread for now so that we can keep track of everything.
    Aug 2010
    Dallas, TX
    4,052
    Stabilizer won't add chlorine, and you have too much. Yes, you should drain your pool by 1/2 at least once to get that stabilizer (CYA) number down. Once you've done that, you need to follow the shock PROCESS. pool-school/shocking_your_pool You are not going to hold chlorine with algae in the pool.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by she1021
    Why did you add stabilzer?
    Please see this pool school article: http://www.troublefreepool.com/pool-...mmended_levels
    With a cya of 120 ppm, you will need to do a partial drain/refill to lower your cya back down to 30-50 ppm. Unfortunatly that is where you were before you added the stabilzer last night
    Butterfly's Avatar
    South Carolina
    10,045
    Are you certain about the CYA being 120? How did you test for it?
    What test kit are you using?
    You're done SLAMing when:
