Results 1 to 8 of 8
Thread: Liner problem??
    Aug 2011
    Blanchard, Oklahoma
    26
    Liner problem??
    My liner appears to have slipped down a little bit in a couple of spots. Is this a major issue and if so how can I fix it?. I have tried to just push it back up with my hand but I can't get it back up enough to catch the lip.
    Thanks
    30ft x 54in AGP 24,900 gallons
    400 lbs High Rate Sand filter
    2HP, 2 speed pump
    Pool Install April 2012
    22,543
    Re: Liner problem??
    Post a pic of it and maybe it can be fixed. Some hot water poured over it will usually help.
    Aug 2011
    Blanchard, Oklahoma
    26
    Re: Liner problem??
    Here is the picture
    2HP, 2 speed pump
    Re: Liner problem??
    What type of liner is that (overlap, jhook or vbead)?? Also have you inspected the cove below the waterline when the liner has dropped to make sure you don't have settling or other issues?
    24 Ft Sharkline Matrix , ~15,200 Gallons
    Pentair SD60 w/ 2 speed 1.5 HP Dynamo pump
    Taylor K-2006 --- BBB
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Liner problem??
    That looks a lot like the liner I had before my current one. It's a Blue Sapphire with a J-hook at the top of the liner. I would take the top seat off of a section or three and see what's going on. My pool has the liner, a resin track to hold the liner in place and then the top seat. I think on an overlap liner you add a coping strip. I would see if you can take off the top seat, pull the liner back over the wall and re-install everything. It should be OK to remove the top rail and other items from a couple sections without damaging the pool.
    -- Guy --
    Aug 2011
    Blanchard, Oklahoma
    26
    Re: Liner problem??
    The cove appears to be fine. It is just happening around the deck so I am assuming it is from the kids jumping of the rail. I am not sure though.
    2HP, 2 speed pump
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Liner problem??
    Have you had a chance to pull off the top seats and corner caps around the deck? I am going to guess it's a pretty simple fix.
    It seems if the kids stood on the top seat to jump in that it could have pinched the bead and pulled it over the top of the wall.
    -- Guy --
    Aug 2011
    Blanchard, Oklahoma
    26
    Re: Liner problem??
    I called the pool store and they are coming Wednesday to fix it. I will let you know how it goes.
    2HP, 2 speed pump
