Results 1 to 11 of 11
Thread: New Pool for me...
    New Pool for me...
    Well I just bought a new house...The pool is clear after a fight with algae...
    Here's my numbers for a 30,000 gallon gunite pool . DE filter.
    Tested last night
    FC 8ppm
    CC 1ppm
    TC 9ppm
    CYA 37ppm
    TA(100)
    pH 7.8
    CH 320
    Tested this morning
    FC 8ppm
    CC 1ppm
    TC 9ppm
    How long does it take to CC's to lower back to 0, If the algae is gone? or does the CC at 1ppm mean that I still have algae?
    ~25,000 gallon
    In Ground Pool
    Gunite/Plaster/DE Filter
    Using a TF-100XL from http://tftestkits.net
    Dolphin Dynamic bought 4/2013-pretty happy with it
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: New Pool for me...
    Algae may not be completely gone. Have you backwashed the DE Filter? Some may be lurking there.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    No I didn't backwash yesterday...planned on it tonight...Do I need to push it back to shock level or can I let it lower? Would love to have the pool ready for this weekend for the kiddo's birthday party...
    ~25,000 gallon
    In Ground Pool
    Mar 2011
    Sunny Central Florida
    91
    I would keep it at shock level until the CC's are gone. CC's make my kids stinky like chlorine after they swim. Not good at a party, LOL.
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
    Backwashed and Pushed it up to shock level
    So I must have a bit of algae...
    last night
    FC 16.5ppm
    CC 1ppm
    this morning
    FC 15ppm
    CC 1ppm
    ~25,000 gallon
    In Ground Pool
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    But you're getting close if the water is clear! It seems there's an inverse proportion for how long it takes to get the last bit versus the first big step; green-to-blue takes much less time than clear to sparkling.
    It might be time to wrestle with the light and clean out anything behind it. And don't skimp on brushing, what's left is obviously a hardy strain of algae! Get a hand brush and get inside the skimmer mouth, too.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Quote Originally Posted by Richard320
    Some Borates never hurt with the sparkling!
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by Vette
    That may be true, but Borates come after everything else is under control.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    That I'll agree with When all his chemicals are in range and the water is clear (and passes the OCLT), then Borates can be introduced if he chooses.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    If you push hard tonight and do as suggested above, you may be able to get ready for the party.
    Also, if the FC is below shock, its OK to swim. I might be hard on the suits but it's a party, I would have my kids swim if I were below shock for the party and then push it back up as soon as the kids get out of the pool to go in for cake and ice cream. Hose the kids off when they get out. I would then close the pool to the kiddos and all other swimmers.
    I think of Borates as what you do after your other numbers have been in range for a month and your bored doing the other things and want that extra sparkle.
    What type DE filter do you have? Does it have a bump handle?
    -- Guy --
    I have a Push/Pull DE Filter...I've scrubbed the pool...scrubbed the tile(which had some scum on the side)...pushed back to shock levels...we'll see if we pass the OCLT tonight...
    ~25,000 gallon
    In Ground Pool
